跳转到主内容
Nokia Lumia 521 Headphone Jack Replacement
你所需要的
  1. Nokia Lumia 521 Headphone Jack Replacement, Battery: 步骤 1 中的图像 1,2 Nokia Lumia 521 Headphone Jack Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
  3. Nokia Lumia 521 Headphone Jack Replacement, SIM Card: 步骤 3 中的图像 1,1
    • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
  4. Nokia Lumia 521 Headphone Jack Replacement, Motherboard: 步骤 4 中的图像 1,2 Nokia Lumia 521 Headphone Jack Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Using the Torx T5 screw head, remove all screws. Note that there are two different sized screws. Five screws are 5 mm long and four are 4 mm long.
    • Five 5 mm screws.
    • Four 4 mm screws.
  5. Nokia Lumia 521 Headphone Jack Replacement: 步骤 5 中的图像 1,2 Nokia Lumia 521 Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Using a plastic opening tool, pry apart the inner back case apart from the rest of the phone, starting at the top and prying while going around the phone.
  6. Nokia Lumia 521 Headphone Jack Replacement: 步骤 6 中的图像 1,2 Nokia Lumia 521 Headphone Jack Replacement: 步骤 6 中的图像 2,2
    • Unclasp the motherboard from the black case clasps using a plastic opening tool.
  7. Nokia Lumia 521 Headphone Jack Replacement: 步骤 7 中的图像 1,2 Nokia Lumia 521 Headphone Jack Replacement: 步骤 7 中的图像 2,2
    • Unclip the motherboard clasps using your fingers or a plastic opening tool.
  8. Nokia Lumia 521 Headphone Jack Replacement, Headphone Jack: 步骤 8 中的图像 1,2 Nokia Lumia 521 Headphone Jack Replacement, Headphone Jack: 步骤 8 中的图像 2,2
    • Gently pry audio jack with your hand until it is removed from its space on the phone.
  9. Nokia Lumia 521 Headphone Jack Replacement: 步骤 9 中的图像 1,1
    • Unclasp the golden flap attached to the audio jack using the plastic opening tool (The top golden flap should already be unclasped from removing the motherboard).
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 2-4, Sullivan Spring 2016 USF Tampa, Team 2-4, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 319
