跳转到主内容
Nokia Lumia 520 Audio Jack Replacement
你所需要的
  1. Nokia Lumia 520 Audio Jack Replacement, Battery: 步骤 1 中的图像 1,2 Nokia Lumia 520 Audio Jack Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Audio Jack Replacement: 步骤 2 中的图像 1,2 Nokia Lumia 520 Audio Jack Replacement: 步骤 2 中的图像 2,2
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Audio Jack Replacement: 步骤 3 中的图像 1,2 Nokia Lumia 520 Audio Jack Replacement: 步骤 3 中的图像 2,2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
  4. Nokia Lumia 520 Audio Jack Replacement, Audio Jack: 步骤 4 中的图像 1,3 Nokia Lumia 520 Audio Jack Replacement, Audio Jack: 步骤 4 中的图像 2,3 Nokia Lumia 520 Audio Jack Replacement, Audio Jack: 步骤 4 中的图像 3,3
    • Unscrew the 8 screws with a Torx screw driver (T4) and make sure you know what screws went where because they are different.
  5. Nokia Lumia 520 Audio Jack Replacement: 步骤 5 中的图像 1,2 Nokia Lumia 520 Audio Jack Replacement: 步骤 5 中的图像 2,2
    • Use your plastic spudger to remove the clips on the plastic casing over the motherboard. Note there are 10 clips holding the casing on(3 on the sides, 2 on the top and bottom).
  6. Nokia Lumia 520 Audio Jack Replacement: 步骤 6 中的图像 1,2 Nokia Lumia 520 Audio Jack Replacement: 步骤 6 中的图像 2,2
    • Carefully unclip the digitizer touch screen cable and the display screen cable using the spudger.
  7. Nokia Lumia 520 Audio Jack Replacement: 步骤 7 中的图像 1,2 Nokia Lumia 520 Audio Jack Replacement: 步骤 7 中的图像 2,2
    • Gently remove the motherboard.
  8. Nokia Lumia 520 Audio Jack Replacement: 步骤 8 中的图像 1,2 Nokia Lumia 520 Audio Jack Replacement: 步骤 8 中的图像 2,2
    • Use the plastic spudger and gently remove the audio jack and the flex connector to the audio jack away from the case.
    • You will feel some pressure since the audio jack is held in place with two sided tape.
结论
5等其他人完成本指南。
Tyler Chellis
于11/03/15注册
249 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 UMass Dartmouth, Team 1-5, Bhusal Fall 2015 的会员
UMASSD-BHUSAL-F15S1G5
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 2,637
