跳转到主内容
Nokia Lumia 2520 Display Assembly Replacement
你所需要的
  1. Nokia Lumia 2520 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,1
    • Apply heat pad to each side of the device.
    • When using any heat pad please use some form of padded gloves so you don't burn you fingers.
    • Microwave the pad for 30 seconds so an ample amount of heat is given on all four sides. Do not microwave more than once every two minutes.
  2. Nokia Lumia 2520 Display Assembly Replacement: 步骤 2 中的图像 1,3 Nokia Lumia 2520 Display Assembly Replacement: 步骤 2 中的图像 2,3 Nokia Lumia 2520 Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass.
    • When pulling the screen off the chassis, be careful not to cut the ribbon cable that connects the screen to the logic board.
    • Take your time to pry open the screen from the chassis as you can easily break the screen or crack it.
  3. Nokia Lumia 2520 Display Assembly Replacement: 步骤 3 中的图像 1,2 Nokia Lumia 2520 Display Assembly Replacement: 步骤 3 中的图像 2,2
    • Pull the ribbon cable out from the connection port on the board.
    • Move on the step 4 to remove the ribbon connection from the screen.
  4. Nokia Lumia 2520 Display Assembly Replacement: 步骤 4 中的图像 1,3 Nokia Lumia 2520 Display Assembly Replacement: 步骤 4 中的图像 2,3 Nokia Lumia 2520 Display Assembly Replacement: 步骤 4 中的图像 3,3
    • Use the plastic pry tool to remove both of the connections.
  5. Nokia Lumia 2520 Display Assembly Replacement: 步骤 5 中的图像 1,1
    • Set aside the screen and the display assembly for repair.
结论
Daniel Chevalier
于09/05/18注册
121 声望
撰写一个指南
团队
Gateway, Team S1-G4, Luster Fall 2018 Gateway, Team S1-G4, Luster Fall 2018 的会员
GCC-LUSTER-F18S1G4
5 名成员
创作了5篇指南
一条评论
What if i clipped the ribbon cable step 2 told me not to... like in half? Springging for a new screen i assume. Ive repaired ribbons before and it doesnt look like theres enough cable left to splice.
Hunter - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 899
