当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
In order to remove the back cover, you must press the indicated button.
With the button pressed, apply light pressure and slide the back cover off.
This will allow you to access the battery
In order to remove the battery, pull it out from the same side that the rubber button is on.
Using a plastic opening tool, separate the back cover from the phone.
Continue along the edge with the plastic opening tool.
Gently, remove the back cover.
Unscrew the indicated screws using the T5 screwdriver.
Open the phone up and use the plastic opening tool to remove the cover to the keyboard.
Be careful not to break the plastic during this step; do your best not to force anything.
The button board will be loose once the cover is removed.
Lift it up to reveal the sensor board.
With the T5 Screwdriver, remove the marked screws.
With the screws removed, the sensor board should be free to flip up.
Disconnect the wire with the plastic opening tool.
Remove the screws marked.
The Screw on the left is located underneath the cable.
With those screws removed, the circuit board and sensor board will be detached from the rest of the phone.
取消:我没有完成这个指南。
4等其他人完成本指南。
与5其他贡献者
于04/12/11注册
540 声望
创作了6篇指南
徽章: 11
+ 8更多徽章
CPSU-GARNER-S11S18G21
3 名成员
创作了8篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 6,316
