本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Start with the phone in the flipped open position.
You must remove the sticker in the center, below the screen to reveal the center screw.
Use a T5 screwdriver to remove all three screws, loosening the front screen.
With the front cover off, the screen and keypad should be loose.
After removing the front screen and front keypad, your device should look like this.
In order to install a new screen, simply follow the steps in reverse order with the new screen.
4等其他人完成本指南。
