跳转到主内容
Nokia E90 Front Screen and Front Keypad Replacement
你所需要的
  1. Nokia E90 Front Screen and Front Keypad Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
  2. Nokia E90 Front Screen and Front Keypad Replacement: 步骤 2 中的图像 1,2 Nokia E90 Front Screen and Front Keypad Replacement: 步骤 2 中的图像 2,2
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
  3. Nokia E90 Front Screen and Front Keypad Replacement, Front Screen and Front Keypad: 步骤 3 中的图像 1,1
    • With the front cover off, the screen and keypad should be loose.
  4. Nokia E90 Front Screen and Front Keypad Replacement: 步骤 4 中的图像 1,2 Nokia E90 Front Screen and Front Keypad Replacement: 步骤 4 中的图像 2,2
    • Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone.
    • With the cable disconnected, the screen should be free for removal or replacement.
结论
In order to reassemble the front screen or install a new screen, follow the steps provided, in reverse order.
另外一个人完成了本指南。
团队
Cal Poly, Team 18-21, Garner Spring 2011 Cal Poly, Team 18-21, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G21
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 6,271
