当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove battery
Using Torx number 4 unscrew the four 0.5mm screws.
Push in four clips to detach the body.
Separate the body into two pieces.
Be careful not to damage the screen or body. Some force will be needed to separate the body.
Remove the bottom piece that is clipped on.
Some force will need to be exerted to remove the clip.
Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
Once screws are removed detach back of phone from the motherboard.
This will require some force and maneuvering. Be careful not to break phone back or motherboard.
Replace motherboard, ensure that replacement has the same serial number.
Carefully un-clip camera ribbon. Install new camera.
取消:我没有完成这个指南。
3等其他人完成本指南。
与7其他贡献者
于08/29/11注册
187 声望
创作了4篇指南
徽章: 7
+ 4更多徽章
CUESTA-ZIPPERIAN-F11S1G1
3 名成员
Will a Nokia E72 replacement camera part work in the Nokia E71 motherboard? In other words, can one upgrade the Nokia E71’s 3.2 MP camera to 5.0 MP using a spare part made for an E72?
Gam - 2017年11月11日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,444
