跳转到主内容
Nokia E61i Front Cover Replacement
你所需要的
  1. Nokia E61i Front Cover Replacement, Battery: 步骤 1 中的图像 1,2 Nokia E61i Front Cover Replacement, Battery: 步骤 1 中的图像 2,2
    • First, gather all necessary tools.
    • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing down on the tab.
  2. Nokia E61i Front Cover Replacement: 步骤 2 中的图像 1,1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Front Cover Replacement: 步骤 3 中的图像 1,1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Front Cover Replacement, Front Cover: 步骤 4 中的图像 1,2 Nokia E61i Front Cover Replacement, Front Cover: 步骤 4 中的图像 2,2
    • To remove the top of the back cover, pry the sides and pop it off.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Front Cover Replacement: 步骤 5 中的图像 1,1
    • Remove the cover by pulling it up and off.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G63
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 2,905
