跳转到主内容
Nokia E61i Connector Housing Replacement
你所需要的
  1. Nokia E61i Connector Housing Replacement, Battery: 步骤 1 中的图像 1,2 Nokia E61i Connector Housing Replacement, Battery: 步骤 1 中的图像 2,2
    • First, gather all necessary tools.
    • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing down on the tab.
  2. Nokia E61i Connector Housing Replacement: 步骤 2 中的图像 1,1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Connector Housing Replacement: 步骤 3 中的图像 1,1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Connector Housing Replacement, Front Cover: 步骤 4 中的图像 1,2 Nokia E61i Connector Housing Replacement, Front Cover: 步骤 4 中的图像 2,2
    • To remove the top of the back cover, pry the sides and pop it off.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Connector Housing Replacement: 步骤 5 中的图像 1,1
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Connector Housing Replacement, Display: 步骤 6 中的图像 1,2 Nokia E61i Connector Housing Replacement, Display: 步骤 6 中的图像 2,2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon, disconnecting contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Connector Housing Replacement: 步骤 7 中的图像 1,2 Nokia E61i Connector Housing Replacement: 步骤 7 中的图像 2,2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Nokia E61i Connector Housing Replacement, Motherboard: 步骤 8 中的图像 1,3 Nokia E61i Connector Housing Replacement, Motherboard: 步骤 8 中的图像 2,3 Nokia E61i Connector Housing Replacement, Motherboard: 步骤 8 中的图像 3,3
    • Pull the green motherboard from the back casing.
  9. Nokia E61i Connector Housing Replacement, Connector Housing: 步骤 9 中的图像 1,1
    • Remove the connector housing by pushing and sliding it off the back panel.
    • Be very careful not to lose the small loose spring from behind the button or the small button itself.
结论
团队
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G63
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 2,167
