跳转到主内容
Nokia 8390 Charging Port Replacement
你所需要的
  1. Nokia 8390 Charging Port Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Locate the button on the bottom of the back cover.
  2. Nokia 8390 Charging Port Replacement: 步骤 2 中的图像 1,3 Nokia 8390 Charging Port Replacement: 步骤 2 中的图像 2,3 Nokia 8390 Charging Port Replacement: 步骤 2 中的图像 3,3
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
  3. Nokia 8390 Charging Port Replacement, Outer Case: 步骤 3 中的图像 1,3 Nokia 8390 Charging Port Replacement, Outer Case: 步骤 3 中的图像 2,3 Nokia 8390 Charging Port Replacement, Outer Case: 步骤 3 中的图像 3,3
    • Grasp the top and bottom of the front cover.
    • Grasp the phone body with your other hand.
    • Lightly pull the casing off of the phone.
  4. Nokia 8390 Charging Port Replacement, Motherboard: 步骤 4 中的图像 1,3 Nokia 8390 Charging Port Replacement, Motherboard: 步骤 4 中的图像 2,3 Nokia 8390 Charging Port Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Locate the six star-shaped screws on the phone.
    • Note: There are two on the bottom end, two in the middle, and two on the top end.
    • Remove these screws using the screwdriver.
  5. Nokia 8390 Charging Port Replacement: 步骤 5 中的图像 1,3 Nokia 8390 Charging Port Replacement: 步骤 5 中的图像 2,3 Nokia 8390 Charging Port Replacement: 步骤 5 中的图像 3,3
    • Grab the top and bottom of the phone casing.
    • Carefully pull the motherboard apart from the bottom casing.
    • The circuit board should be divided into two parts.
  6. Nokia 8390 Charging Port Replacement: 步骤 6 中的图像 1,3 Nokia 8390 Charging Port Replacement: 步骤 6 中的图像 2,3 Nokia 8390 Charging Port Replacement: 步骤 6 中的图像 3,3
    • Grab the top and bottom of the remaining casing.
    • Carefully pull apart the casing from the circuit board.
  7. Nokia 8390 Charging Port Replacement: 步骤 7 中的图像 1,1
    • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
  8. Nokia 8390 Charging Port Replacement, Charging Port: 步骤 8 中的图像 1,3 Nokia 8390 Charging Port Replacement, Charging Port: 步骤 8 中的图像 2,3 Nokia 8390 Charging Port Replacement, Charging Port: 步骤 8 中的图像 3,3
    • Hold back of phone in hand so that hand is not covering any parts.
    • Grasp charge port with thumb.
    • Pull out with hand.
结论
2等其他人完成本指南。
Clinton
于10/22/12注册
57 声望
创作了7篇指南
团队
Clemson, Team 14-5, Benson Fall 2012 Clemson, Team 14-5, Benson Fall 2012 的会员
CLEM-BENSON-F12S14G5
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 314
