跳转到主内容
Nokia 8290 Adhesive White Film Replacement
你所需要的
  1. Nokia 8290 Adhesive White Film Replacement, Front Cover: 步骤 1 中的图像 1,3 Nokia 8290 Adhesive White Film Replacement, Front Cover: 步骤 1 中的图像 2,3 Nokia 8290 Adhesive White Film Replacement, Front Cover: 步骤 1 中的图像 3,3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Nokia 8290 Adhesive White Film Replacement, Circuit Board: 步骤 2 中的图像 1,3 Nokia 8290 Adhesive White Film Replacement, Circuit Board: 步骤 2 中的图像 2,3 Nokia 8290 Adhesive White Film Replacement, Circuit Board: 步骤 2 中的图像 3,3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Nokia 8290 Adhesive White Film Replacement: 步骤 3 中的图像 1,3 Nokia 8290 Adhesive White Film Replacement: 步骤 3 中的图像 2,3 Nokia 8290 Adhesive White Film Replacement: 步骤 3 中的图像 3,3
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
  4. Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: 步骤 4 中的图像 1,3 Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: 步骤 4 中的图像 2,3 Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: 步骤 4 中的图像 3,3
    • Hold the faceplate with the adhesive film facing upwards.
    • Use the spudger to pry the adhesive film away. This can be done by working the tool back and forth underneath the film.
    • It is easiest to begin in the upper left corner.
  5. Nokia 8290 Adhesive White Film Replacement: 步骤 5 中的图像 1,3 Nokia 8290 Adhesive White Film Replacement: 步骤 5 中的图像 2,3 Nokia 8290 Adhesive White Film Replacement: 步骤 5 中的图像 3,3
    • Continue to loosen the film with the spudger.
    • Once the film has been mostly loosened, you can peel away the film.
    • Once the film has been removed, the microphone may fall out, if so, place it aside until all other repairs are finished.
结论
团队
Clemson, Team 15-3, Benson Fall 2012 Clemson, Team 15-3, Benson Fall 2012 的会员
CLEM-BENSON-F12S15G3
3 名成员
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 333
