跳转到主内容
Nokia 8265 Logic Board Replacement
你所需要的
  1. Nokia 8265 Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,1
    • Start by removing the face plate of the phone with a plastic tool.
    • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
  2. Nokia 8265 Logic Board Replacement: 步骤 2 中的图像 1,1
    • Once the face plate is off, you will have exposed the keypad.
  3. Nokia 8265 Logic Board Replacement: 步骤 3 中的图像 1,1
    • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
  4. Nokia 8265 Logic Board Replacement: 步骤 4 中的图像 1,1
    • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
    • Make sure to remember what screw goes where.
  5. Nokia 8265 Logic Board Replacement: 步骤 5 中的图像 1,1
    • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
    • The screen section will be able to be removed after Step 4 is finished.
  6. Nokia 8265 Logic Board Replacement: 步骤 6 中的图像 1,1
    • Be careful when removing the Logic Board from the body, lifting it with fingers on both sides to prevent damage of the Logic Board.
    • Separate the Logic Board from the main body of the device.
  7. Nokia 8265 Logic Board Replacement: 步骤 7 中的图像 1,1
    • Insert in the replacement Logic Board, setting the Logic Board carefully back into place.
  8. Nokia 8265 Logic Board Replacement: 步骤 8 中的图像 1,1
    • Set the screen carefully over the body of the phone, avoiding any sliding on the Logic board
  9. Nokia 8265 Logic Board Replacement: 步骤 9 中的图像 1,1
    • Replace screws in the corresponding slots, tightening them till they are not loose.
  10. Nokia 8265 Logic Board Replacement: 步骤 10 中的图像 1,1
    • Replace keypad onto the device
  11. Nokia 8265 Logic Board Replacement: 步骤 11 中的图像 1,1
    • Lastly, you can place the cover onto the phone. You will know when it is in place if you hear a click after placing it in.
终点
Jack
于04/20/12注册
1 声望
创作了4篇指南
团队
SUNY Cortland, Team 1-1, Getto Spring 2012 SUNY Cortland, Team 1-1, Getto Spring 2012 的会员
SUNYCORT-GETTO-S12S1G1
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 1,191
