跳转到主内容
Nokia 8265 Keypad Replacement
你所需要的
  1. Nokia 8265 Keypad Replacement, Keypad: 步骤 1 中的图像 1,1
    • Using a plastic opening tool, wedge the tip of the tool into the side of the phone's faceplate
    • To pry open, wiggle/twist the tip of the tool, until faceplate pops up.
  2. Nokia 8265 Keypad Replacement: 步骤 2 中的图像 1,1
    • Once popped off, remove the faceplate entirely, exposing the keypad.
  3. Nokia 8265 Keypad Replacement: 步骤 3 中的图像 1,1
    • You can pick up the keypad with ease, as it is not attached to the phone itself.
  4. Nokia 8265 Keypad Replacement: 步骤 4 中的图像 1,1
    • To clean keypad if it is not functioning properly, use a cloth to wipe away any spills, or water damage
结论
If cleaning off keypad does not work, insert your new keypad, and follow steps in reverse order to reassemble your device.
Jack
于04/20/12注册
1 声望
创作了4篇指南
团队
SUNY Cortland, Team 1-1, Getto Spring 2012 SUNY Cortland, Team 1-1, Getto Spring 2012 的会员
SUNYCORT-GETTO-S12S1G1
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 821
