跳转到主内容
Nokia 8260 Microphone Replacement
你所需要的
  1. Nokia 8260 Microphone Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the cell phone.
  2. Nokia 8260 Microphone Replacement: 步骤 2 中的图像 1,1
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 Microphone Replacement: 步骤 3 中的图像 1,1
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 Microphone Replacement: 步骤 4 中的图像 1,1
    • Remove the back cover.
  5. Nokia 8260 Microphone Replacement: 步骤 5 中的图像 1,1
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 Microphone Replacement: 步骤 6 中的图像 1,1
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 Microphone Replacement, Antenna: 步骤 7 中的图像 1,1
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 Microphone Replacement: 步骤 8 中的图像 1,1
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 Microphone Replacement: 步骤 9 中的图像 1,1
    • Remove the antenna door.
  10. Nokia 8260 Microphone Replacement: 步骤 10 中的图像 1,1
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
  11. Nokia 8260 Microphone Replacement, Circuit Board: 步骤 11 中的图像 1,1
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
  12. Nokia 8260 Microphone Replacement: 步骤 12 中的图像 1,1
    • Remove the back covering.
  13. Nokia 8260 Microphone Replacement: 步骤 13 中的图像 1,1
    • Remove the two screws at the top.
  14. Nokia 8260 Microphone Replacement: 步骤 14 中的图像 1,1
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
  15. Nokia 8260 Microphone Replacement, Keypad: 步骤 15 中的图像 1,1
    • Remove the plastic border lying on the keypad.
  16. Nokia 8260 Microphone Replacement: 步骤 16 中的图像 1,1
    • Remove the keypad.
    • Depending on what you are doing, you can take out or leave the buttons to the keypad in the front casing.
  17. Nokia 8260 Microphone Replacement, Microphone: 步骤 17 中的图像 1,1
    • Remove the microphone.
结论
Aaron Jen
于04/11/10注册
1 声望
创作了7篇指南
团队
Cal Poly, Team 27-94, Amido Spring 2010 Cal Poly, Team 27-94, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G94
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,215
