当前版本的文档还未经巡查,您可以查看最新的已查核版本。
If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
Try to keep the antenna as flat as possible. Do not bend it.
Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
The two bottom screws are longer than the upper three.
Remove the metal plating and the circuit board.
There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
The LCD will be attached to the circuit board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
