当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Press the button on the bottom of the rear cover.
Keep the button pressed while pulling the cover downward to remove the back cover.
Lift the cover off.
To remove the battery, push it down from the top and pull it out.
Grip the front cover from the bottom.
Lift the front cover off.
Remove the six screws using a T6 torx screwdriver.
Insert spudger along edge of assembly and gently lift assembly away from case
Remove assembly from phone
The logic board now sits on top of the phone.
Lift the logic board out of the phone.
Locate battery charger connector
Grasp top and bottom of battery charger connector on the left side
Lift out the battery charger connector
Grasp vibrator which protrudes from the battery charger connector
Lift the vibrator out of the battery charger connector.
取消:我没有完成这个指南。
与2其他贡献者
于10/05/10注册
1 声望
创作了7篇指南
徽章: 5
+ 2更多徽章
CPSU-MANESS-F10S22G3
4 名成员
创作了9篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 8
总计 1,119
