跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will show you how to remove the phone's vibrator used for the vibrate ring setting
配件
没有特定配件。
  1. Press the button to remove the back cover. Pull the cover downward and lift it off while still pressing the button.
    • Press the button to remove the back cover.
    • Pull the cover downward and lift it off while still pressing the button.
  2. Lift the battery out of the phone by pushing down from the top and pulling out
    • Lift the battery out of the phone by pushing down from the top and pulling out
  3. Grip the front cover from the bottom.
    • Grip the front cover from the bottom.
  4. Lift the front cover off.
    • Lift the front cover off.
  5. Locate 6 screws on front of assembly and unscrew them using a T6 torx screwdriver.
    • Locate 6 screws on front of assembly and unscrew them using a T6 torx screwdriver.
  6. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  7. Insert spudger along edge of assembly and gently lift assembly away from case
    • Insert spudger along edge of assembly and gently lift assembly away from case
  8. Remove assembly from phone
    • Remove assembly from phone
  9. The logic board now sits on top of the phone.
    • The logic board now sits on top of the phone.
  10. Lift the logic board out of the phone.
    • Lift the logic board out of the phone.
  11. Locate battery charger connector
    • Locate battery charger connector
  12. Grasp top and bottom of battery charger connector on the left side
    • Grasp top and bottom of battery charger connector on the left side
  13. Lift out the battery charger connector
    • Lift out the battery charger connector
  14. Grasp vibrator which protrudes from the battery charger connector
    • Grasp vibrator which protrudes from the battery charger connector
  15. Lift the vibrator out of the battery charger connector.
    • Lift the vibrator out of the battery charger connector.
结论
Colby Leslie
于2010年10月05日注册
1 信誉积分
创作了7篇指南
团队
Cal Poly, Team 22-3, Maness Fall 2010 Cal Poly, Team 22-3, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G3
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 1,082
