当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Press the button on the bottom of the rear cover.
Keep the button pressed while pulling the cover downward to remove the back cover.
Lift the cover off.
To remove the battery, push it down from the top and pull it out.
Grip the front cover from the bottom.
Lift the front cover off.
Remove the six screws using a T6 torx screwdriver.
Insert spudger along edge of assembly and gently lift assembly away from case
Remove assembly from phone
Flip assembly over
Locate speaker on the back of the assembly.
Insert spudger under upper left side of speaker and gently lift to remove
Remove speaker.
取消:我没有完成这个指南。
与2其他贡献者
于10/05/10注册
1 声望
创作了7篇指南
徽章: 5
+ 2更多徽章
CPSU-MANESS-F10S22G3
4 名成员
创作了9篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 7
总计 752
