跳转到主内容
Nokia 6590i Battery Charger Connector Replacement
你所需要的
  1. Nokia 6590i Battery Charger Connector Replacement, Battery: 步骤 1 中的图像 1,2 Nokia 6590i Battery Charger Connector Replacement, Battery: 步骤 1 中的图像 2,2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Nokia 6590i Battery Charger Connector Replacement: 步骤 2 中的图像 1,1
    • To remove the battery, push it down from the top and pull it out.
  3. Nokia 6590i Battery Charger Connector Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 步骤 3 中的图像 1,1
    • Grip the front cover from the bottom.
  4. Nokia 6590i Battery Charger Connector Replacement: 步骤 4 中的图像 1,1
    • Lift the front cover off.
  5. Nokia 6590i Battery Charger Connector Replacement: 步骤 5 中的图像 1,1
    • Remove the six screws using a T6 torx screwdriver.
  6. Nokia 6590i Battery Charger Connector Replacement: 步骤 6 中的图像 1,1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Nokia 6590i Battery Charger Connector Replacement: 步骤 7 中的图像 1,1
    • Remove assembly from phone
  8. Nokia 6590i Battery Charger Connector Replacement, Logic Board: 步骤 8 中的图像 1,1
    • The logic board now sits on top of the phone.
  9. Nokia 6590i Battery Charger Connector Replacement: 步骤 9 中的图像 1,1
    • Lift the logic board out of the phone.
  10. Nokia 6590i Battery Charger Connector Replacement, Battery Charger Connector: 步骤 10 中的图像 1,1
    • Locate battery charger connector
  11. Nokia 6590i Battery Charger Connector Replacement: 步骤 11 中的图像 1,1
    • Grasp top and bottom of battery charger connector on the left side
  12. Nokia 6590i Battery Charger Connector Replacement: 步骤 12 中的图像 1,1
    • Lift out the battery charger connector
结论
Colby Leslie
于10/05/10注册
1 声望
创作了7篇指南
团队
Cal Poly, Team 22-3, Maness Fall 2010 Cal Poly, Team 22-3, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G3
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,860
