跳转到主内容
Nokia 6350-1b Battery Replacement
你所需要的
  1. Nokia 6350-1b Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover of the phone by sliding it downwards.
    • This will be a thin panel that has three stripes to provide better grip.
  2. Nokia 6350-1b Battery Replacement: 步骤 2 中的图像 1,1
    • Caution: When you slide the panel downwards, it will immediately come loose.
    • Remove the BP-6MT battery. There should be an indent showing where you will lift.
  3. Nokia 6350-1b Battery Replacement: 步骤 3 中的图像 1,1
    • Once you have removed the old battery, you can begin to install the new battery.
    • Line up the gold indentations in the upper left corner of the battery with the three gold indentations in the upper left hand corner of the empty battery space.
  4. Nokia 6350-1b Battery Replacement: 步骤 4 中的图像 1,1
    • Ensure that when you have lined up the battery, you are able to seamlessly insert into phone.
    • Note: If it does not slide seamlessly, it is not being inserted correctly
  5. Nokia 6350-1b Battery Replacement: 步骤 5 中的图像 1,1
    • After the battery has clicked in, you need to reinstall the back panel of the phone.
    • Line the back panel up with the phone.
  6. Nokia 6350-1b Battery Replacement: 步骤 6 中的图像 1,1
    • Line up the back panel starting from the bottom.
    • Once lined and pressed down, slide upward. You should be able to feel and hear it click back into place.
结论
Anna
于04/13/12注册
21 声望
创作了2篇指南
团队
SUNY Cortland, Team 1-2, Getto Spring 2012 SUNY Cortland, Team 1-2, Getto Spring 2012 的会员
SUNYCORT-GETTO-S12S1G2
2 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 19
总计 1,409
