跳转到主内容
Nokia 6310i Antenna Replacement
你所需要的
  1. Nokia 6310i Antenna Replacement, Battery: 步骤 1 中的图像 1,2 Nokia 6310i Antenna Replacement, Battery: 步骤 1 中的图像 2,2
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Nokia 6310i Antenna Replacement, SIM card: 步骤 2 中的图像 1,3 Nokia 6310i Antenna Replacement, SIM card: 步骤 2 中的图像 2,3 Nokia 6310i Antenna Replacement, SIM card: 步骤 2 中的图像 3,3
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Nokia 6310i Antenna Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Unscrew and remove the four T6 Torx screws.
  4. Nokia 6310i Antenna Replacement: 步骤 4 中的图像 1,3 Nokia 6310i Antenna Replacement: 步骤 4 中的图像 2,3 Nokia 6310i Antenna Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  5. Nokia 6310i Antenna Replacement: 步骤 5 中的图像 1,3 Nokia 6310i Antenna Replacement: 步骤 5 中的图像 2,3 Nokia 6310i Antenna Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
  6. Nokia 6310i Antenna Replacement, Antenna: 步骤 6 中的图像 1,2 Nokia 6310i Antenna Replacement, Antenna: 步骤 6 中的图像 2,2
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
结论
3等其他人完成本指南。
Wilson Tam
于09/29/10注册
77 声望
撰写一个指南
团队
Cal Poly, Team 14-41, Forte Fall 2010 Cal Poly, Team 14-41, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G41
5 名成员
创作了22篇指南
2条评论
Thanks for a nice and helpful instruction.
The rubber power-on button had broken down so I just removed the damaged parts. Now using a toothpick to push the microswitch directly.
Only using the phone indoors for nostalgic reasons, playing Snake :-)
Brgrds Ove
ove.tandberg - 回复
Thanks for antenna help
I have had about three 6310i’s and the on/off button was the failure problem in all three.
Andrew Richards - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 29
总计 8,263
