跳转到主内容
加入维修社区 - 创建账户
Nokia 6236i Front Casing Replacement
你所需要的
  1. Nokia 6236i Front Casing Replacement, Battery: 步骤 1 中的图像 1,2 Nokia 6236i Front Casing Replacement, Battery: 步骤 1 中的图像 2,2
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Nokia 6236i Front Casing Replacement: 步骤 2 中的图像 1,3 Nokia 6236i Front Casing Replacement: 步骤 2 中的图像 2,3 Nokia 6236i Front Casing Replacement: 步骤 2 中的图像 3,3
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Nokia 6236i Front Casing Replacement, SIM Card: 步骤 3 中的图像 1,3 Nokia 6236i Front Casing Replacement, SIM Card: 步骤 3 中的图像 2,3 Nokia 6236i Front Casing Replacement, SIM Card: 步骤 3 中的图像 3,3
    • Once the battery is removed, pull the tab of the metal sim card cover, and lift it up.
    • The sim card is underneath and can now be removed.
  4. Nokia 6236i Front Casing Replacement, Front Casing: 步骤 4 中的图像 1,3 Nokia 6236i Front Casing Replacement, Front Casing: 步骤 4 中的图像 2,3 Nokia 6236i Front Casing Replacement, Front Casing: 步骤 4 中的图像 3,3
    • Insert a spudger into the indention on the bottom right side of the device.
    • Slide the spudger upward to a second indention at the top of the phone.
    • The front casing will detach from the phone.
结论
The front casing will be detached without causing damage to the case or phone model.
For reassembly, complete the listed steps in reverse.
Erik Lindahl
于04/18/10注册
63 声望
创作了4篇指南
团队
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 的会员
CPSU-GARNER-S10S10G46
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 2,016
