跳转到主内容
Nokia 6200 Classic Circuit Board Replacement
你所需要的
  1. Nokia 6200 Classic Circuit Board Replacement, Front Plate: 步骤 1 中的图像 1,3 Nokia 6200 Classic Circuit Board Replacement, Front Plate: 步骤 1 中的图像 2,3 Nokia 6200 Classic Circuit Board Replacement, Front Plate: 步骤 1 中的图像 3,3
    • Pull up on both of the clips near the bottom of the phone as shown.
    • Lift off the front plate.
  2. Nokia 6200 Classic Circuit Board Replacement: 步骤 2 中的图像 1,1
    • The keypad and LCD screen are revealed.
  3. Nokia 6200 Classic Circuit Board Replacement, Circuit Board: 步骤 3 中的图像 1,2 Nokia 6200 Classic Circuit Board Replacement, Circuit Board: 步骤 3 中的图像 2,2
    • Separate the keypad from the phone and place aside.
    • Wipe off any excess dust from where the keypad was attached to the phone.
  4. Nokia 6200 Classic Circuit Board Replacement: 步骤 4 中的图像 1,2 Nokia 6200 Classic Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Remove the 6 - 7.9 mm screws highlighted by the markers using the T-6 head on the screwdriver.
  5. Nokia 6200 Classic Circuit Board Replacement: 步骤 5 中的图像 1,2 Nokia 6200 Classic Circuit Board Replacement: 步骤 5 中的图像 2,2
    • Separate the inside of the phone from the back of the phone.
  6. Nokia 6200 Classic Circuit Board Replacement: 步骤 6 中的图像 1,2 Nokia 6200 Classic Circuit Board Replacement: 步骤 6 中的图像 2,2
    • Gently pull apart the circuit board from the rest of the phone.
    • There is a small connector holding these two pieces together, so use caution when pulling apart so as not to damage it.
结论
To reattach the circuit board, line up the connector at the top of the board with the back of the LCD Screen attachment. Place the two boards together, and screw in the 6 screws.
Reid Polstra
于10/22/12注册
1 声望
创作了7篇指南
团队
Clemson, Team 15-5, Benson Fall 2012 Clemson, Team 15-5, Benson Fall 2012 的会员
CLEM-BENSON-F12S15G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 767
