跳转到主内容
修复你的物品
维修的权力
配件 & 工具
配件
没有特定配件。
  1. Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone. Lift off back cover.
    • Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
    • Lift off back cover.
  2. Use your index finger to first push down and then lift up the battery as shown. Remove battery from cell phone. Remove battery from cell phone.
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove battery from cell phone.
  3. Unscrew two T5 torx screws easily visible on the back side of the cell phone Screws: 7.8mm
    • Unscrew two T5 torx screws easily visible on the back side of the cell phone
    • Screws: 7.8mm
    • Once screw are removed, the phone will separate easily into two pieces connected by a flexible wire strip.
    • Be sure to not lose or disconnect the indicated piece that the screw mounts to. It is spring loaded and is very dificult to reattach.
  4. 基本电子产品工具包
    小工具包。却有无限可能。
    Shop Toolkits
    基本
    电子产品
    工具包
    Shop Toolkits
  5. Use an iPod opening tool to gently pry open the back case as indicated in the picture. Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary) REPEAT on both sides, and be careful not to stab the circuitry with the tools.
    • Use an iPod opening tool to gently pry open the back case as indicated in the picture.
    • Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary)
    • REPEAT on both sides, and be careful not to stab the circuitry with the tools.
  6. Gently pull the phone apart and the flexible wire should detach from its connection as shown. If not, lift up on the black tab within the left box in the picture. With the front half of the phone, push the keypad towards the removed portion of the phone.
    • Gently pull the phone apart and the flexible wire should detach from its connection as shown.
    • If not, lift up on the black tab within the left box in the picture.
    • With the front half of the phone, push the keypad towards the removed portion of the phone.
    • To clean, use a damp cloth with water.
  7. Use a T6 Torx Screwdriver to remove the screw located in the bottom right corner of the back panel.
    • Use a T6 Torx Screwdriver to remove the screw located in the bottom right corner of the back panel.
    • Screw: 6.4 mm
  8. Lift up from the top of the logic board as shown to remove. Lift up from the top of the logic board as shown to remove.
    • Lift up from the top of the logic board as shown to remove.
结论
另外一个人完成了本指南。
Vincent Benvin
于2010年04月19日注册
121 信誉积分
创作了4篇指南
团队
Cal Poly, Team 23-82, Johann Spring 2010 Cal Poly, Team 23-82, Johann Spring 2010 的会员
CPSU-JOHANN-S10S23G82
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,681
