跳转到主内容
Nokia 6133 Keypad Replacement
你所需要的
  1. Nokia 6133 Keypad Replacement, Battery: 步骤 1 中的图像 1,2 Nokia 6133 Keypad Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
    • Lift off back cover.
  2. Nokia 6133 Keypad Replacement: 步骤 2 中的图像 1,3 Nokia 6133 Keypad Replacement: 步骤 2 中的图像 2,3 Nokia 6133 Keypad Replacement: 步骤 2 中的图像 3,3
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove battery from cell phone.
  3. Nokia 6133 Keypad Replacement, Keypad: 步骤 3 中的图像 1,2 Nokia 6133 Keypad Replacement, Keypad: 步骤 3 中的图像 2,2
    • Unscrew two T5 torx screws easily visible on the back side of the cell phone
    • Screws: 7.8mm
    • Once screw are removed, the phone will separate easily into two pieces connected by a flexible wire strip.
    • Be sure to not lose or disconnect the indicated piece that the screw mounts to. It is spring loaded and is very dificult to reattach.
  4. Nokia 6133 Keypad Replacement: 步骤 4 中的图像 1,3 Nokia 6133 Keypad Replacement: 步骤 4 中的图像 2,3 Nokia 6133 Keypad Replacement: 步骤 4 中的图像 3,3
    • Use an iPod opening tool to gently pry open the back case as indicated in the picture.
    • Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary)
    • REPEAT on both sides, and be careful not to stab the circuitry with the tools.
  5. Nokia 6133 Keypad Replacement: 步骤 5 中的图像 1,3 Nokia 6133 Keypad Replacement: 步骤 5 中的图像 2,3 Nokia 6133 Keypad Replacement: 步骤 5 中的图像 3,3
    • Gently pull the phone apart and the flexible wire should detach from its connection as shown.
    • If not, lift up on the black tab within the left box in the picture.
    • With the front half of the phone, push the keypad towards the removed portion of the phone.
    • To clean, use a damp cloth with water.
结论
另外一个人完成了本指南。
Vincent Benvin
于04/19/10注册
121 声望
创作了4篇指南
团队
Cal Poly, Team 23-82, Johann Spring 2010 Cal Poly, Team 23-82, Johann Spring 2010 的会员
CPSU-JOHANN-S10S23G82
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,957
