跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Nokia 6108,请使用我们的维修手册
  1. Nokia 6108 Teardown, Nokia 6108 Teardown: 步骤 1 中的图像 1,1
    • Hello,I'm going to open my phone for some fun.
    • Be careful not to drop any screws or parts when you're opening your phone.This may render your phone not usuable.Open your phone at your own risk.
  2. Nokia 6108 Teardown: 步骤 2 中的图像 1,2 Nokia 6108 Teardown: 步骤 2 中的图像 2,2
    • Remove the following parts.
    • Battery cover
    • Battery
    • SIM card
    • Remove two trox screws marked in figure 2.
  3. Nokia 6108 Teardown: 步骤 3 中的图像 1,2 Nokia 6108 Teardown: 步骤 3 中的图像 2,2
    • Remove the front panel by pulling it or using an
    • I don't have a opening tool.So I used a flathead screw driver instead.
    • Be careful not the damage the number pad connector(highlighted in red).If you break it.You'll have to replace the entre front panel.
  4. Nokia 6108 Teardown: 步骤 4 中的图像 1,2 Nokia 6108 Teardown: 步骤 4 中的图像 2,2
    • Remove 5 trox screws that are holding the screen and the touch pad.
  5. Nokia 6108 Teardown: 步骤 5 中的图像 1,2 Nokia 6108 Teardown: 步骤 5 中的图像 2,2
    • After removing the touch pad and the screen.You can remove the logic board from the case.
    • The board seem don't want to leave its cozy home.
  6. Nokia 6108 Teardown: 步骤 6 中的图像 1,1
    • Let's start removing the parts under the logic board.
    • Parts need to be removed.
    • A motor
    • Charger connector
    • A speaker
  7. Nokia 6108 Teardown: 步骤 7 中的图像 1,1
    • Removing the EMI shield.Pry around the edge of the shield to remove it.
  8. Nokia 6108 Teardown: 步骤 8 中的图像 1,2 Nokia 6108 Teardown: 步骤 8 中的图像 2,2
    • Nothing under the EMI shield.
    • I think we should stop here right now.There are pictures for all parts.
Honam1021
于02/19/11注册
349 声望
撰写一个指南
一条评论
i have same phone but it's keypad button's are not working.... can u help me that
Rohit Yadav - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 16
总计 4,728
