跳转到主内容
Nokia 6102i motherboard replacement
你所需要的
  1. Nokia 6102i motherboard replacement, Battery: 步骤 1 中的图像 1,3 Nokia 6102i motherboard replacement, Battery: 步骤 1 中的图像 2,3 Nokia 6102i motherboard replacement, Battery: 步骤 1 中的图像 3,3
    • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
    • Note: Images on the right side may be hovered over to reveal larger versions.
  2. Nokia 6102i motherboard replacement: 步骤 2 中的图像 1,1
    • Lift up the battery from the inside of the phone.
    • Make sure to lift up from the bottom of the battery as shown.
    • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
  3. Nokia 6102i motherboard replacement: 步骤 4 中的图像 1,2 Nokia 6102i motherboard replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to remove the silver cover over the antenna.
    • The covering may not pop right off. It may require some prying in different locations around the top covering.
  4. Nokia 6102i motherboard replacement: 步骤 5 中的图像 1,2 Nokia 6102i motherboard replacement: 步骤 5 中的图像 2,2
    • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
  5. Nokia 6102i motherboard replacement: 步骤 6 中的图像 1,2 Nokia 6102i motherboard replacement: 步骤 6 中的图像 2,2
    • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
    • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • Disconnect the logic board from the small orange chip.
结论
2等其他人完成本指南。
Alex Graebe
于04/15/10注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 23-78, Johann Spring 2010 Cal Poly, Team 23-78, Johann Spring 2010 的会员
CPSU-JOHANN-S10S23G78
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,629
