当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
Lift out battery and remove.
Use your finger to lift the metal cage up.
Remove SIM card.
Use your finger to close the metal cage.
Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
After removing the top cover, turn the phone over so the screen is facing upwards.
Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
Remove the six screws found along the frame of the phone with a T6 Torx screwdriver and put them to the side.
Gently lift the top of the screen up.
Be cautious of loose parts.
Gently pull up on the grey plastic tab.
取消:我没有完成这个指南。
2等其他人完成本指南。
与6其他贡献者
于04/14/10注册
316 声望
创作了9篇指南
徽章: 14
+ 11更多徽章
CPSU-JOHANN-S10S23G63
3 名成员
创作了17篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 9
总计 6,933
