跳转到主内容
配件
没有特定配件。
  1. 这个步骤还没有翻译 帮忙翻译一下
    Press the small tab on the bottom of the back of the phone. Push the back case upward towards the power button. The back case will then pop off. It requires some force, so be careful.
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. 这个步骤还没有翻译 帮忙翻译一下
    Lift the battery near the bottom and pry up. Lift the battery near the bottom and pry up.
    • Lift the battery near the bottom and pry up.
  3. 这个步骤还没有翻译 帮忙翻译一下
    With one hand, press the ridged tab near the visible side of the SIM card.
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  4. 这个步骤还没有翻译 帮忙翻译一下
    Grip the phone on either the sides, the top, or the bottom. Pull the front case away from the rest of the phone.
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5. 这个步骤还没有翻译 帮忙翻译一下
    Lift the keypad away from the body of the phone.
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
终点
2等其他人完成本指南。
Nicholas Hanne
于2010年01月20日注册
60 信誉积分
创作了8篇指南
团队
Cal Poly, Team 14-45, Regan Winter 2010 Cal Poly, Team 14-45, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G45
5 名成员
创作了16篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 2,997
