跳转到主内容
Nokia 515 Front cover and keypad replacement
你所需要的
  1. Nokia 515 Front cover and keypad replacement, Front cover and keypad: 步骤 1 中的图像 1,1
    • Remove the back cover with your fingers or with the eject tool which is included by Nokia.
    • Don't forget to turn off your device!
  2. Nokia 515 Front cover and keypad replacement: 步骤 2 中的图像 1,1
    • Remove the battery, the microSD card and the SIM card.
  3. Nokia 515 Front cover and keypad replacement: 步骤 3 中的图像 1,1
    • Remove the 2 screws with the T4 screwdriver.
    • Please store the screws on a safe place! I already lost a screw!
  4. Nokia 515 Front cover and keypad replacement: 步骤 4 中的图像 1,2 Nokia 515 Front cover and keypad replacement: 步骤 4 中的图像 2,2
    • Take the metal spudger and pry it firmly under the plastic hinges.
    • Although you want to replace the cover, be very careful by doing it! You could harm yourself with the metal spudger.
    • You could also use your fingers instead of the spudger to do it!
  5. Nokia 515 Front cover and keypad replacement, Remove the keypad: 步骤 5 中的图像 1,3 Nokia 515 Front cover and keypad replacement, Remove the keypad: 步骤 5 中的图像 2,3 Nokia 515 Front cover and keypad replacement, Remove the keypad: 步骤 5 中的图像 3,3
    • To remove the keypad, you should use the spudger to push the top clamps down a little bit while pressing your fingers against the inside of the keypad.
    • The keypad should be loose at the top.
    • To remove the bottom, just use a little bit of force to pull it off the front panel.
    • Just use a little bit of force.
  6. Nokia 515 Front cover and keypad replacement: 步骤 6 中的图像 1,1
    • To assemble the new keypad, start at the upper half of the keyboard.
  7. Nokia 515 Front cover and keypad replacement: 步骤 7 中的图像 1,3 Nokia 515 Front cover and keypad replacement: 步骤 7 中的图像 2,3 Nokia 515 Front cover and keypad replacement: 步骤 7 中的图像 3,3
    • To reassemble the front, just click it in place (you hear a clicking noise).
    • Now screw the T4 screws back into the holes.
    • Now you put the microSD card, the SIM card and the battery back into your device.
    • Now you can turn on your device.
结论
You did it!
2等其他人完成本指南。
由衷感谢以下译者:
de en
100%
Leon正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Leon
于03/28/19注册
346 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 694
