跳转到主内容
Nokia 5130 XpressMusic Logic Board / Casing Replacement
你所需要的
  1. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Sliding off the rear panel: 步骤 1 中的图像 1,1
    • Slide the rear panel in the indicated direction to unlock it.
  2. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Lifting up the rear panel: 步骤 2 中的图像 1,2 Nokia 5130 XpressMusic Logic Board / Casing Replacement, Lifting up the rear panel: 步骤 2 中的图像 2,2
    • After unlocking it, the rear panel can now be lifted up.
  3. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Rear screws: 步骤 3 中的图像 1,1
    • Remove the two T6 screws near the camera
  4. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Unclip the bezel: 步骤 4 中的图像 1,1
    • Unclip the several clips holding the front bezel in place
    • Be sure not to break off or damage the clips, otherwise the front bezel might no longer stay in place!
  5. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Keypad: 步骤 5 中的图像 1,1
    • Push in the pins holding in the keypad
  6. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Remove the keypad: 步骤 6 中的图像 1,1
    • The keypad can now be removed.
  7. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Remove the remaining parts: 步骤 7 中的图像 1,1
    • Lift up the logic board / display and remove it from the case.
结论
另外一个人完成了本指南。
iSzymon
于10/13/20注册
630 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 447
