当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
Lift the back plate off the phone.
To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
Lift the battery out of the phone.
Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
Use finger nails of your thumbs to gently pull apart the face plate.
While the face plate is pulled apart, use index fingers to pull inner case towards you.
Separate faceplate and inner case.
Gently peel up the edge of plastic keypad from the inside of the faceplate to remove.
取消:我没有完成这个指南。
3等其他人完成本指南。
与5其他贡献者
于01/26/10注册
69 声望
创作了2篇指南
徽章: 7
+ 4更多徽章
CPSU-REGAN-W10S8G39
4 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 16
总计 3,701
