跳转到主内容
Nokia 3310 3G Screen Replacement
你所需要的
  1. Nokia 3310 3G Screen Replacement, Battery: 步骤 1 中的图像 1,2 Nokia 3310 3G Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Screen Replacement: 步骤 2 中的图像 1,2 Nokia 3310 3G Screen Replacement: 步骤 2 中的图像 2,2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Screen Replacement, Frame: 步骤 3 中的图像 1,3 Nokia 3310 3G Screen Replacement, Frame: 步骤 3 中的图像 2,3 Nokia 3310 3G Screen Replacement, Frame: 步骤 3 中的图像 3,3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Screen Replacement, Motherboard: 步骤 4 中的图像 1,3 Nokia 3310 3G Screen Replacement, Motherboard: 步骤 4 中的图像 2,3 Nokia 3310 3G Screen Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Screen Replacement, Screen: 步骤 5 中的图像 1,3 Nokia 3310 3G Screen Replacement, Screen: 步骤 5 中的图像 2,3 Nokia 3310 3G Screen Replacement, Screen: 步骤 5 中的图像 3,3
    • With the motherboard removed, the only thing holding the screen into place is the snap plug on the back of the motherboard.
    • Using a spudger, leverage the top snap up to disconnect it (photo shows motherboard rotated 90 degrees counterclockwise).
结论
4等其他人完成本指南。
Aaron LeBlanc
于10/24/18注册
735 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G3
3 名成员
创作了16篇指南
3条评论
If you can break the screen without taking it apart, then you must not be human
Feyrowan - 回复
The Cylons are greeting you.
M. H. -
Thank you!
I dont have cash for a new one,
but i could fix my old one.
There was soup on the display inside,
cleaned it, screen is clear now.
Yeay!
fred - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 21
总计 1,823
