跳转到主内容
Nokia 3310 3G Outer Frame Replacement
你所需要的
  1. Nokia 3310 3G Outer Frame Replacement, Battery: 步骤 1 中的图像 1,2 Nokia 3310 3G Outer Frame Replacement, Battery: 步骤 1 中的图像 2,2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Outer Frame Replacement: 步骤 2 中的图像 1,2 Nokia 3310 3G Outer Frame Replacement: 步骤 2 中的图像 2,2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Outer Frame Replacement, Frame: 步骤 3 中的图像 1,3 Nokia 3310 3G Outer Frame Replacement, Frame: 步骤 3 中的图像 2,3 Nokia 3310 3G Outer Frame Replacement, Frame: 步骤 3 中的图像 3,3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Outer Frame Replacement, Motherboard: 步骤 4 中的图像 1,3 Nokia 3310 3G Outer Frame Replacement, Motherboard: 步骤 4 中的图像 2,3 Nokia 3310 3G Outer Frame Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Outer Frame Replacement, Speaker: 步骤 5 中的图像 1,2 Nokia 3310 3G Outer Frame Replacement, Speaker: 步骤 5 中的图像 2,2
    • Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
    • Use the metal spudger to leverage out the speaker.
    • The speaker is attached to the shell with an adhesive. Do not be too aggressive in your removal, else the speaker will come apart.
  6. Nokia 3310 3G Outer Frame Replacement, Outer Frame: 步骤 6 中的图像 1,1
    • Using your finger, push the keyboard insert out of the front outer frame.
结论
7等其他人完成本指南。
Aaron LeBlanc
于10/24/18注册
735 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G3
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 1,107
