跳转到主内容
加入维修社区 - 创建账户
Nokia 3300B Keyboard Replacement.
  1. Nokia 3300B Keyboard Replacement., Battery: 步骤 1 中的图像 1,2 Nokia 3300B Keyboard Replacement., Battery: 步骤 1 中的图像 2,2
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Nokia 3300B Keyboard Replacement.: 步骤 2 中的图像 1,2 Nokia 3300B Keyboard Replacement.: 步骤 2 中的图像 2,2
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Nokia 3300B Keyboard Replacement., Keyboard: 步骤 3 中的图像 1,2 Nokia 3300B Keyboard Replacement., Keyboard: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
  4. Nokia 3300B Keyboard Replacement.: 步骤 4 中的图像 1,1
    • With the screen still facing you, lift and remove the blue faceplate.
  5. Nokia 3300B Keyboard Replacement.: 步骤 5 中的图像 1,1
    • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
    • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
结论
3等其他人完成本指南。
Chris Colwell
于04/13/10注册
116 声望
创作了2篇指南
团队
Cal Poly, Team 18-65, Johann Spring 2010 Cal Poly, Team 18-65, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G65
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 3,125
