跳转到主内容
Nokia 3120 SIM Card Replacement
你所需要的
  1. Nokia 3120 SIM Card Replacement, Battery Installation: 步骤 1 中的图像 1,3 Nokia 3120 SIM Card Replacement, Battery Installation: 步骤 1 中的图像 2,3 Nokia 3120 SIM Card Replacement, Battery Installation: 步骤 1 中的图像 3,3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 SIM Card Replacement: 步骤 2 中的图像 1,1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 SIM Card Replacement, SIM Card: 步骤 3 中的图像 1,1
    • Once the battery is removed, the SIM card compartment will be exposed. Pry the compartment open as seen in the figure. This can be done using your fingernail or a prying mechanism.
  4. Nokia 3120 SIM Card Replacement: 步骤 4 中的图像 1,1
    • Once the SIM card compartment has been opened, insert the SIM card into the slot provided on the left side.
结论
3等其他人完成本指南。
Justin Emerson
于03/11/13注册
163 声望
创作了2篇指南
团队
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G2
3 名成员
创作了14篇指南
一条评论
Thanks , appreciated.
Ian McCully - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 21
总计 5,433
