跳转到主内容
Nokia 3120 Liquid Crystal Display (LCD) Replacement
你所需要的
  1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: 步骤 1 中的图像 1,3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: 步骤 1 中的图像 2,3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: 步骤 1 中的图像 3,3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 Liquid Crystal Display (LCD) Replacement: 步骤 2 中的图像 1,1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: 步骤 3 中的图像 1,3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: 步骤 3 中的图像 2,3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: 步骤 3 中的图像 3,3
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Liquid Crystal Display (LCD): 步骤 4 中的图像 1,1
    • Once the cover plate has been removed, the keypad should easily pop out.
  5. Nokia 3120 Liquid Crystal Display (LCD) Replacement: 步骤 5 中的图像 1,2 Nokia 3120 Liquid Crystal Display (LCD) Replacement: 步骤 5 中的图像 2,2
    • Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
  6. Nokia 3120 Liquid Crystal Display (LCD) Replacement: 步骤 6 中的图像 1,1
    • Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
  7. Nokia 3120 Liquid Crystal Display (LCD) Replacement: 步骤 7 中的图像 1,1
    • Take out the cell phone electronic board
  8. Nokia 3120 Liquid Crystal Display (LCD) Replacement: 步骤 8 中的图像 1,1
    • The LCD screen can now be removed from the body of the phone.
结论
2等其他人完成本指南。
Pierre Tong
于03/11/13注册
77 声望
创作了4篇指南
团队
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G2
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 1,401
