跳转到主内容
Nokia 3.1 Battery Replacement
你所需要的
  1. Nokia 3.1 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • First, remove the SIM and SD card trays.
  2. Nokia 3.1 Battery Replacement, Open the back cover: 步骤 2 中的图像 1,3 Nokia 3.1 Battery Replacement, Open the back cover: 步骤 2 中的图像 2,3 Nokia 3.1 Battery Replacement, Open the back cover: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Try to use a thin tool like a razor blade to start to pry open the back cover.
    • When you opened it up just a little bit put a plastic card or a plastic opening tool inside the gap.
    • Using the plastic tool slowly make your way around the back cover. You can also use a guitar pick or similar.
    • Hint: the back cover is attached to the body with several plastic noses as well as a thin strip of adhesive. The cover is quite flexible and sturdy.
  3. Nokia 3.1 Battery Replacement, Remove logic board cover: 步骤 3 中的图像 1,2 Nokia 3.1 Battery Replacement, Remove logic board cover: 步骤 3 中的图像 2,2
    • Remove the seven Torx T5 screws from the logic board cover.
    • Remove the logic board cover.
    • Lift up the battery connector from the logic board.
  4. Nokia 3.1 Battery Replacement, Remove battery adhesive strips: 步骤 4 中的图像 1,2 Nokia 3.1 Battery Replacement, Remove battery adhesive strips: 步骤 4 中的图像 2,2
    • At the bottom end of the battery you will see two black ends of adhesive strips showing up from underneath the battery.
    • Slowly pull at those adhesive strip ends to be able to lift out the battery.
结论
To reassemble your device, follow these instructions in reverse order. Also don’t forget some double-faced adhesive tape to fixate the new battery.
9等其他人完成本指南。
Baschtl
于12/02/12注册
1,552 声望
创作了5篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 84
总计 6,806
