跳转到主内容
Nokia 2630b LCD Display Replacement
你所需要的
  1. Nokia 2630b LCD Display Replacement, LCD Display: 步骤 1 中的图像 1,3 Nokia 2630b LCD Display Replacement, LCD Display: 步骤 1 中的图像 2,3 Nokia 2630b LCD Display Replacement, LCD Display: 步骤 1 中的图像 3,3
    • Remove the Back cover by Pressing the release buttons located on either side of the battery cover
    • Now Remove The Battery and Simcard from the slots
  2. Nokia 2630b LCD Display Replacement: 步骤 2 中的图像 1,3 Nokia 2630b LCD Display Replacement: 步骤 2 中的图像 2,3 Nokia 2630b LCD Display Replacement: 步骤 2 中的图像 3,3
    • Remove the two screws on either side of the back side using the microscrewdriver using the T5 bit
    • Now Remove the Front key panel from the Main Board Carefully using the Plastic Opening Tools
  3. Nokia 2630b LCD Display Replacement: 步骤 3 中的图像 1,3 Nokia 2630b LCD Display Replacement: 步骤 3 中的图像 2,3 Nokia 2630b LCD Display Replacement: 步骤 3 中的图像 3,3
    • Now Remove the four screws in the front side of the main board
    • Now push the Board from the Battery slot side and carefully By using the Plastic Opening Tools Separate the board from the back case or rear case
  4. Nokia 2630b LCD Display Replacement: 步骤 4 中的图像 1,2 Nokia 2630b LCD Display Replacement: 步骤 4 中的图像 2,2
    • Now Gently Separate the lock at the right side to remove the outer cover of the Main Board
    • !!!! Be Cautious that the key panel is attached at the other end
  5. Nokia 2630b LCD Display Replacement: 步骤 5 中的图像 1,3 Nokia 2630b LCD Display Replacement: 步骤 5 中的图像 2,3 Nokia 2630b LCD Display Replacement: 步骤 5 中的图像 3,3
    • Remove the Chip which is attached to the main board
    • Now we can separate the display from the main board and we can replace it with the new display.
结论
2等其他人完成本指南。
LOGESAM
于12/28/15注册
123 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 321
