跳转到主内容
Nokia 2630b Antenna Replacement
你所需要的
  1. Nokia 2630b Antenna Replacement, Battery Case: 步骤 1 中的图像 1,2 Nokia 2630b Antenna Replacement, Battery Case: 步骤 1 中的图像 2,2
    • Press each release button on either side of the battery cover and simultaneously remove the battery cover from the phone.
  2. Nokia 2630b Antenna Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out of the phone with your fingers.
  3. Nokia 2630b Antenna Replacement, Screen / Front Case: 步骤 3 中的图像 1,1
    • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
    • NOTE: Keep the screws in a safe place while you continue working.
  4. Nokia 2630b Antenna Replacement: 步骤 4 中的图像 1,3 Nokia 2630b Antenna Replacement: 步骤 4 中的图像 2,3 Nokia 2630b Antenna Replacement: 步骤 4 中的图像 3,3
    • Separate the front case from the back case using the iPod opener
    • NOTE: The keypad is a loose piece and may fall out
  5. Nokia 2630b Antenna Replacement: 步骤 5 中的图像 1,1
    • Remove screws using the same T5 screw bit to release the computer chip from the case
  6. Nokia 2630b Antenna Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the black frame off the screen with your fingers
  7. Nokia 2630b Antenna Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the computer chip and screen out of the black case with your fingers
  8. Nokia 2630b Antenna Replacement: 步骤 8 中的图像 1,2 Nokia 2630b Antenna Replacement: 步骤 8 中的图像 2,2
    • The screen is attached to the motherboard by an orange ribbon
    • Carefully detach the ribbon from the motherboard using your fingers
  9. Nokia 2630b Antenna Replacement: 步骤 9 中的图像 1,1
    • Reattach new screen by connecting the orange ribbon to the computer chip
  10. Nokia 2630b Antenna Replacement: 步骤 10 中的图像 1,2 Nokia 2630b Antenna Replacement: 步骤 10 中的图像 2,2
    • Place computer chip and screen back into black case
  11. Nokia 2630b Antenna Replacement: 步骤 11 中的图像 1,1
    • Place black frame back over screen
  12. Nokia 2630b Antenna Replacement: 步骤 12 中的图像 1,2 Nokia 2630b Antenna Replacement: 步骤 12 中的图像 2,2
    • Carefully place keypad back in place
  13. Nokia 2630b Antenna Replacement: 步骤 13 中的图像 1,2 Nokia 2630b Antenna Replacement: 步骤 13 中的图像 2,2
    • Snap the front case back in place with the bottom case with your fingers
  14. Nokia 2630b Antenna Replacement: 步骤 14 中的图像 1,1
    • Reassemble screws with microscrewdriver
  15. Nokia 2630b Antenna Replacement: 步骤 15 中的图像 1,1
    • Slide battery back into place
  16. Nokia 2630b Antenna Replacement: 步骤 16 中的图像 1,1
    • Snap battery cover back into place
  17. Nokia 2630b Antenna Replacement, Back Case: 步骤 17 中的图像 1,2 Nokia 2630b Antenna Replacement, Back Case: 步骤 17 中的图像 2,2
    • Locate the four screws that secure the back case to the rest of the phone.
    • Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
  18. Nokia 2630b Antenna Replacement: 步骤 18 中的图像 1,3 Nokia 2630b Antenna Replacement: 步骤 18 中的图像 2,3 Nokia 2630b Antenna Replacement: 步骤 18 中的图像 3,3
    • DO NOT PULL APART! There is a wire attaching the speaker to the rear case. It is very important to NOT sever this connection. Because of this, the rear case does not completely detach from the rest of the phone.
    • Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
  19. Nokia 2630b Antenna Replacement, Antenna: 步骤 19 中的图像 1,1
    • The antenna is the "L" shaped device located on the top of the phone in between the back case and the board.
    • You should be able to remove the antenna with minimal effort.
    • To put in a new antenna, place it in the same location as the old one. There is no need to connect to any hardware on the phone.
  20. Nokia 2630b Antenna Replacement: 步骤 20 中的图像 1,1
    • To reassemble the device, follow the instructions in reverse order.
    • When reinstalling the keyboard, make sure it is in the correct position before screwing the case back together.
    • When reinstalling the battery, make sure the contacts of the battery connect to the contacts on the phone.
    • The red square in the photo indicates the position of the brass contacts of the battery.
    • The photo displays the correct orientation of the battery.
终点
Eric
于04/07/11注册
51 声望
创作了4篇指南
团队
Cal Poly, Team 9-61, Walters Spring 2011 Cal Poly, Team 9-61, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G61
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 3,401
