跳转到主内容
Nokia 2610 Keypad Replacement
你所需要的
  1. Nokia 2610 Keypad Replacement, Battery and Sim Card: 步骤 1 中的图像 1,3 Nokia 2610 Keypad Replacement, Battery and Sim Card: 步骤 1 中的图像 2,3 Nokia 2610 Keypad Replacement, Battery and Sim Card: 步骤 1 中的图像 3,3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Keypad Replacement: 步骤 2 中的图像 1,3 Nokia 2610 Keypad Replacement: 步骤 2 中的图像 2,3 Nokia 2610 Keypad Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Keypad Replacement: 步骤 3 中的图像 1,3 Nokia 2610 Keypad Replacement: 步骤 3 中的图像 2,3 Nokia 2610 Keypad Replacement: 步骤 3 中的图像 3,3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Keypad Replacement, Front Pannel: 步骤 4 中的图像 1,2 Nokia 2610 Keypad Replacement, Front Pannel: 步骤 4 中的图像 2,2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Keypad Replacement: 步骤 5 中的图像 1,2 Nokia 2610 Keypad Replacement: 步骤 5 中的图像 2,2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  6. Nokia 2610 Keypad Replacement, Keypad: 步骤 6 中的图像 1,2 Nokia 2610 Keypad Replacement, Keypad: 步骤 6 中的图像 2,2
    • Push on the keypad from the exterior of the phone's front cover to separate the keypad from the phone.
结论
Jeff Carter
于10/05/10注册
94 声望
撰写一个指南
团队
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G52
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 2,155
