跳转到主内容
加入维修社区 - 创建账户
Nokia 2610 Front Pannel Replacement
你所需要的
  1. Nokia 2610 Front Pannel Replacement, Battery and Sim Card: 步骤 1 中的图像 1,3 Nokia 2610 Front Pannel Replacement, Battery and Sim Card: 步骤 1 中的图像 2,3 Nokia 2610 Front Pannel Replacement, Battery and Sim Card: 步骤 1 中的图像 3,3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
    添加评论
  2. Nokia 2610 Front Pannel Replacement: 步骤 2 中的图像 1,3 Nokia 2610 Front Pannel Replacement: 步骤 2 中的图像 2,3 Nokia 2610 Front Pannel Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    询问修复机器人
    添加评论
  3. Nokia 2610 Front Pannel Replacement: 步骤 3 中的图像 1,3 Nokia 2610 Front Pannel Replacement: 步骤 3 中的图像 2,3 Nokia 2610 Front Pannel Replacement: 步骤 3 中的图像 3,3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
    询问修复机器人
    添加评论
  4. Nokia 2610 Front Pannel Replacement, Front Pannel: 步骤 4 中的图像 1,2 Nokia 2610 Front Pannel Replacement, Front Pannel: 步骤 4 中的图像 2,2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
    询问修复机器人
    添加评论
  5. Nokia 2610 Front Pannel Replacement: 步骤 5 中的图像 1,2 Nokia 2610 Front Pannel Replacement: 步骤 5 中的图像 2,2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Andrew Wood
于10/05/10注册
336 声望
创作了3篇指南
团队
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G52
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 36
总计 2,497
