本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
Insert the plastic opening tool into the crack between the front and back panels.
Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
5等其他人完成本指南。
