跳转到主内容
Nokia 2128i Logic Board Replacement
你所需要的
  1. Nokia 2128i Logic Board Replacement, Battery: 步骤 1 中的图像 1,3 Nokia 2128i Logic Board Replacement, Battery: 步骤 1 中的图像 2,3 Nokia 2128i Logic Board Replacement, Battery: 步骤 1 中的图像 3,3
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Logic Board Replacement: 步骤 2 中的图像 1,3 Nokia 2128i Logic Board Replacement: 步骤 2 中的图像 2,3 Nokia 2128i Logic Board Replacement: 步骤 2 中的图像 3,3
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Logic Board Replacement, Faceplate: 步骤 3 中的图像 1,3 Nokia 2128i Logic Board Replacement, Faceplate: 步骤 3 中的图像 2,3 Nokia 2128i Logic Board Replacement, Faceplate: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Logic Board Replacement, Keypad: 步骤 4 中的图像 1,3 Nokia 2128i Logic Board Replacement, Keypad: 步骤 4 中的图像 2,3 Nokia 2128i Logic Board Replacement, Keypad: 步骤 4 中的图像 3,3
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Logic Board Replacement, Motherboard Assembly: 步骤 5 中的图像 1,3 Nokia 2128i Logic Board Replacement, Motherboard Assembly: 步骤 5 中的图像 2,3 Nokia 2128i Logic Board Replacement, Motherboard Assembly: 步骤 5 中的图像 3,3
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Logic Board Replacement: 步骤 6 中的图像 1,3 Nokia 2128i Logic Board Replacement: 步骤 6 中的图像 2,3 Nokia 2128i Logic Board Replacement: 步骤 6 中的图像 3,3
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Logic Board Replacement, Logic Board: 步骤 7 中的图像 1,3 Nokia 2128i Logic Board Replacement, Logic Board: 步骤 7 中的图像 2,3 Nokia 2128i Logic Board Replacement, Logic Board: 步骤 7 中的图像 3,3
    • Locate the two plastic LCD unit hooks.
    • Pry hooks outward.
  8. Nokia 2128i Logic Board Replacement: 步骤 8 中的图像 1,3 Nokia 2128i Logic Board Replacement: 步骤 8 中的图像 2,3 Nokia 2128i Logic Board Replacement: 步骤 8 中的图像 3,3
    • Gently pull LCD unit away from the logic board.
    • Be careful not to damage the connection on the top, right hand side of the logic board.
结论
Chad
于10/29/10注册
19 声望
创作了5篇指南
团队
Cal Poly, Team 20-8, Maness Fall 2010 Cal Poly, Team 20-8, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G8
4 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,249
