Insert the plastic opening tool under the faceplate.
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
添加评论
With the faceplate removed, simply peel off rubber key pad and remove.
  • With the faceplate removed, simply peel off rubber key pad and remove.
添加评论
  • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
添加评论
  • After removing screws, lift the motherboard assembly straight off the cell phone body.
添加评论
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
添加评论
  • Using your fingernail, pry the back of the battery upwards and pull out.
添加评论
  • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
添加评论
结论
Andres Echeverria
于2010年10月29日注册
4 信誉积分
创作了3篇指南
团队
Cal Poly, Team 20-8, Maness Fall 2010 Cal Poly, Team 20-8, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G8
4 名成员
创作了28篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 217
