跳转到主内容
Nokia 2115i Faceplate Replacement
你所需要的
  1. Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: 步骤 1 中的图像 1,3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: 步骤 1 中的图像 2,3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: 步骤 1 中的图像 3,3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i Faceplate Replacement: 步骤 2 中的图像 1,2 Nokia 2115i Faceplate Replacement: 步骤 2 中的图像 2,2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i Faceplate Replacement, Faceplate: 步骤 3 中的图像 1,3 Nokia 2115i Faceplate Replacement, Faceplate: 步骤 3 中的图像 2,3 Nokia 2115i Faceplate Replacement, Faceplate: 步骤 3 中的图像 3,3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
结论
Shane
于09/30/10注册
80 声望
创作了6篇指南
团队
Cal Poly, Team 14-38, Forte Fall 2010 Cal Poly, Team 14-38, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G38
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,536
