跳转到主内容
Nokia 1100b RH-36 Speaker Replacement
你所需要的
  1. Nokia 1100b RH-36 Speaker Replacement, Battery Cover: 步骤 1 中的图像 1,2 Nokia 1100b RH-36 Speaker Replacement, Battery Cover: 步骤 1 中的图像 2,2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Speaker Replacement, Battery: 步骤 2 中的图像 1,1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Speaker Replacement, Inner Casing: 步骤 3 中的图像 1,2 Nokia 1100b RH-36 Speaker Replacement, Inner Casing: 步骤 3 中的图像 2,2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  4. Nokia 1100b RH-36 Speaker Replacement, Screen: 步骤 4 中的图像 1,2 Nokia 1100b RH-36 Speaker Replacement, Screen: 步骤 4 中的图像 2,2
    • Flip over the metal frame you just removed.
    • Using the flat end of the spudger, pry apart the inner clear plastic frame with screen attached from the metal frame.
    • Remove the screen bearing plastic frame.
  5. Nokia 1100b RH-36 Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 Nokia 1100b RH-36 Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Gently remove the speaker from the top of the metal frame.
结论
4等其他人完成本指南。
JSwan
于04/12/13注册
781 声望
创作了6篇指南
团队
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G43
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 2,065
