跳转到主内容
Nokia 1100b RH-36 Keypad Replacement
你所需要的
  1. Nokia 1100b RH-36 Keypad Replacement, Removing Nokia 1100b RH-36 Front Cover: 步骤 1 中的图像 1,2 Nokia 1100b RH-36 Keypad Replacement, Removing Nokia 1100b RH-36 Front Cover: 步骤 1 中的图像 2,2
    • Firmly grip the back of the casing.
    • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
    • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
  2. Nokia 1100b RH-36 Keypad Replacement, Keypad: 步骤 2 中的图像 1,1
    • Using the flat end of the spudger, push out the 4 rubber tabs on the back of the keypad to remove it.
结论
3等其他人完成本指南。
JSwan
于04/12/13注册
751 声望
创作了6篇指南
团队
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G43
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 1,876
