跳转到主内容
Nokero SunRay Pro Power Panel USB Assembly Replacement
你所需要的
  1. Nokero SunRay Pro Power Panel USB Assembly Replacement, Front and Back Case: 步骤 1 中的图像 1,1
    • Turn over the device so that the back of the device is facing up.
  2. Nokero SunRay Pro Power Panel USB Assembly Replacement: 步骤 2 中的图像 1,3 Nokero SunRay Pro Power Panel USB Assembly Replacement: 步骤 2 中的图像 2,3 Nokero SunRay Pro Power Panel USB Assembly Replacement: 步骤 2 中的图像 3,3
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
  3. Nokero SunRay Pro Power Panel USB Assembly Replacement: 步骤 3 中的图像 1,2 Nokero SunRay Pro Power Panel USB Assembly Replacement: 步骤 3 中的图像 2,2
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
  4. Nokero SunRay Pro Power Panel USB Assembly Replacement: 步骤 4 中的图像 1,2 Nokero SunRay Pro Power Panel USB Assembly Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
  5. Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: 步骤 5 中的图像 1,2 Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: 步骤 5 中的图像 2,2
    • Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly.
结论
另外一个人完成了本指南。
Nicholas Orr
于01/20/15注册
229 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 312
