跳转到主内容
Nokero Shavano N220 Batteries Replacement
你所需要的
  1. Nokero Shavano N220 Batteries Replacement, Batteries: 步骤 1 中的图像 1,3 Nokero Shavano N220 Batteries Replacement, Batteries: 步骤 1 中的图像 2,3 Nokero Shavano N220 Batteries Replacement, Batteries: 步骤 1 中的图像 3,3
    • Use one hand to hold the device still and the other to remove the lid by turning it clockwise using your index finger and thumb.
  2. Nokero Shavano N220 Batteries Replacement: 步骤 2 中的图像 1,3 Nokero Shavano N220 Batteries Replacement: 步骤 2 中的图像 2,3 Nokero Shavano N220 Batteries Replacement: 步骤 2 中的图像 3,3
    • Using your index finger and thumb, squeeze the top and bottom of the plastic bezel together, and lift it off of the device.
  3. Nokero Shavano N220 Batteries Replacement: 步骤 3 中的图像 1,3 Nokero Shavano N220 Batteries Replacement: 步骤 3 中的图像 2,3 Nokero Shavano N220 Batteries Replacement: 步骤 3 中的图像 3,3
    • Insert a spudger into the slot at the bottom of the lower battery cover, and pry the cover up.
    • You only need to apply minimal pressure to lift the cover. If you force it too hard, you may snap the plastic.
    • Repeat for the second battery cover.
  4. Nokero Shavano N220 Batteries Replacement: 步骤 4 中的图像 1,3 Nokero Shavano N220 Batteries Replacement: 步骤 4 中的图像 2,3 Nokero Shavano N220 Batteries Replacement: 步骤 4 中的图像 3,3
    • Use a spudger or your fingers to remove the two batteries.
  5. Nokero Shavano N220 Batteries Replacement: 步骤 5 中的图像 1,3 Nokero Shavano N220 Batteries Replacement: 步骤 5 中的图像 2,3 Nokero Shavano N220 Batteries Replacement: 步骤 5 中的图像 3,3
    • Now take your new batteries or let the old ones charge and reinsert them.
    • Follow the picture of the battery on the inside of the device.
  6. Nokero Shavano N220 Batteries Replacement: 步骤 6 中的图像 1,3 Nokero Shavano N220 Batteries Replacement: 步骤 6 中的图像 2,3 Nokero Shavano N220 Batteries Replacement: 步骤 6 中的图像 3,3
    • Once you have put in both sides, insert the covers.
    • Match the ends and it should just pop into place.
  7. Nokero Shavano N220 Batteries Replacement: 步骤 7 中的图像 1,3 Nokero Shavano N220 Batteries Replacement: 步骤 7 中的图像 2,3 Nokero Shavano N220 Batteries Replacement: 步骤 7 中的图像 3,3
    • Almost there, now take the white piece that you set aside and squeeze one side once again using your pointer finger and thumb to put it in.
    • Take the lid and turn it counter clockwise using your index finger and thumb.
结论
另外一个人完成了本指南。
Erica Hill
于10/28/13注册
523 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 338
